rockhillmanor wrote:
I'll just ad my obligatory statement of what happened to me when I had a super garage built for my MH. Something you need to keep in mind so it doesn't happen to you.
We measured the MH to the top of the ac unit. Measured and checked it twice and added for insurance. AND then told the contractor how tall of a door we needed.
Only thing was no one checked with the contractor of the building. Foundation was built up and they added a concrete pad to the entrance.
That small slope of the concrete pad leading to the garage was just enough to NOT allow my MH under the door on the approach. :(
If you entry is completely flat your ok but if there is going to be any type of incline you have to account for that and make allowances when ordering the height of your door.
Mr. Rock,
What did you do to fix it?MM.
Sadly nothing could be done. The math to extend the concrete pad leading to the barn to make it accessible for the MH to level out was not doable.
I can't imagine building a beautiful RV garage like you built and not being able to use it. How much would it have cost to adjust the entrance?
I guess I don't understand the significance of the slope being such and issue unless the margins were just too close.
I hope this eventually works out for you whether you change coaches, fix the garage or sell the property.
MM.
