turbojimmy's avatar
turbojimmy
Gas line for Norcold 8310
I googled parts for a Norcold 8310 and can only come up with circuit boards. I need the aluminum line that runs from the gas valve to the burner. Any ideas where to get? It looks pretty generic - flare on one end, compression fitting on the other.
  • Follow up:
    I hadn't really used the fridge on propane beyond the testing I did when I first installed the line. Let it run a few hours on propane with no incident. While getting ready for an upcoming trip, I noticed that I hadn't put the cover back on the burner box for the fridge when I did that gas line repair. I put it on and while securing it with the screw there was a POOOOF! and bright orange flame in the box. I ran inside and shut the fridge off and pondered what had happened. Not being sure what the cause was, I did it again with the same results.
    Long story short, the new line was leaking at the burner. Without the cover on the firebox the leak got enough fresh air to not ignite. With the cover on the box the propane was able to build up enough for the burner flame to ignite it. I had to crank down that compression fitting REALLY, REALLY tight in order for it to seal. It's okay now....
    Just some words to the wise.
  • Gjac's avatar
    Gjac
    Explorer III
    I had this problem on my Norcold 682 model. They no longer made the tube or the burner. I bought the newer style burner and had to cut the compression fitting off and flare the end for the new burner.
  • For the record, I got this from Amazon for $11:
    https://www.amazon.com/gp/product/B000E297FI/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
    It came with the right compression fitting for the pilot end. I used the old flare fitting on the feed end (used my flare kit to put a flare on it). It comes with enough tubing that you can screw up and start over again.
    Fridge works great now. It wasn't staying lit - I suspected a kink in the old pilot tube which is why I messed with it and ultimately broke it. Stays lit now!
