blkcloud01 wrote:
In the market for a motorhome, sold my pull behind camper.. looking to spend around 40k.. will probably use it 3-4 times a year.. just wondering.. about gas or diesel.. from what I have been seeing for sale, I can buy a 2000 diesel pusher or I can buy a newer gas say a 2005 for the same money.. your opinions please..thanks!
All the advice above is good. EVERYTHING depends on your situation. Do you primarily like to boondock, RV parks only? Will your 3-4 times a year turn into more? Are you retired or close to it?
Don't make the mistake of buying and then changing your mind. That can get expensive real fast.
I always read before we purchased our first unit (the Dynasty), is to buy your third motorhome first. I really feel that is what we did. A gas engine was not an option as I wanted a full size motorhome with 4 slides and a tandem axle. We have been very happy with our choice.
Now, 7 yrs. later, I want to upgrade to our last full size coach that should take us 15+ yrs. After that, it will be over or maybe a class B.
We didn't waste money buying units then changing our minds. I took a lot of time reading everything I could get my hands on, reading RV sites, magazines, etc., before we actually ordered the first one.
Also, we rented 3 units before we bought (One 31 ft. class C with one slide, 2 class A diesels, the first had 3 slides, the second had 4 slides). I knew the diesel was the way to go for us.
Good luck and hope that you find the perfect unit.
MM.
