Davydd wrote:
davegvg wrote:
Advanced RV puts diesel gensets in non cab chassis class B's
I previously mentioned I don't recall Advanced RV putting a diesel generator in a Sprinter van. Can you cite a specific example? Advanced RV does custom work, to a degree, for their customers and it might be possible they did a one off for a customer and they only build on Sprinter 170" wheelbase vans. Their base standard is to use diesel powered heating and on demand hot water, but that is not using a generator. Their main emphasis of late has been their ecOasis system of solar, multi-battery banks, second under hood alternator and large inverter charger to eliminate propane and generator.
According to Mike on his videos he does. Do you hold the registry of each one built?
UD
