Colo_Native
Aug 29, 2017Explorer
Gas or DP
I am looking to go back to a MH, I want spend $70K -100K. It appears I could get a 3-4 old gas or a 8-10 year DP. I like the idea of a DP but wonder if the life is used up on a 10 year old DP and I ho...
Colo Native wrote:One thing to keep in mind is a short gas MH with 362 HP and weights 16,000 lbs will have a higher HP/wt ratio than a 300 or 340 HP DP that is closer to 30,000 lbs. Gas MH's have the same engine whether it is 28 ft or 38 ft. DP's HP go up as the length and weight go up.Busskipper wrote:Colo Native wrote:
I am looking to go back to a MH, I want spend $70K -100K. It appears I could get a 3-4 old gas or a 8-10 year DP. I like the idea of a DP but wonder if the life is used up on a 10 year old DP and I how much $$ to update on one. I have had a gas before and I know they are slow and noisy in the Rockies. Any thoughts.
Only you will Know the right unit for You - Floor plan and Level of Fit and finish will likely be the deciding factors.
IMHO, the older diesel will give you more of what you are looking for.
Comfort - Ride - Build level - just a better House.
Just a guess but I think you have a strong lean for the Diesel.
Have you narrowed down the list to a Manufacturer, or two? Think that will help.
In all honesty the size limit you have will tend to be very limited in the used market, and as you know there are just so many more 40' Coaches.
So, if I were you, figure out the Type - Diesel or Gas - ID your level of Finish (Not just on the surface) - Narrow down to couple of Manufacturers - Search till you drop.
Then run the heck out of it, see the rest of the Country,
Now ----- what will be the Toad?????????????? Be sure the selected Coach can pull it where you will travel.
A 400HP non DEF should be possible, and would be my preference
Keep us all in the Loop as this will be FUN to watch as it evolves.
Best of Luck,
ps. as I've read many or your posts over the last few years - you have a strong knowledge of your needs and what will work - my story is I had a gas unit that just could not handle Colorado so I had a Diesel Build - we selected a Hydro Hot because we use it in the winter - This is a BIG DEAL - so just keep that in mind - Insulation is also Critical if you use it in the Fall/Spring/Winter.
Colorado is hard on gassers going up the hills at 35MPH and 4500rpm slow and noisy Been there done that but then again I don't know if a 300-340 HP dp is much better
