RayChez wrote:
1BryNelson wrote:
RayChez says a dp is better in a crosswind than a gasser. You are a nut. And how do you justify a statement like that!
I can tell you do not know anything between a gasoline coach and a diesel pusher. I do not want to start a big argument about which is bothered by cross winds and which is not. All I will say is test drive both on windy days and you will see that it is like day and night in the difference. You can ask anybody that has had both and they will tell you the same thing.
I used to love the floor plan of my 36'gasoline coach, but driving back from Utah going through the Virgin River gorge it was so windy and I could barely keep the coach on my side of the two lane road. Now with this 38' diesel pusher I hardly notice any wind buffing. It would have to be very strong winds to notice. I say the weight difference between the coaches. My gasoline coach weight 19K lbs, the diesel pusher weighs 39K lbs. That is a difference of 20K lbs. Plus the diesel pusher has bigger and better sway bars, airbags that adjust automatic.
You are comparing apples to oranges and making a blanket statement. You had a light weight gasser and you are assuming that all gassers handle the same as yours. One of the heavy weight gasser chassis, like the W24 will handle differently than your 19K F53 chassis. It also makes a huge difference if your weight is not distributed properly. Too light on the front axle of a gasser OR a DP and the coach will wander all over, no matter what air bags or trac bars you have on the rear. If you use just weight as your determining factor, than every automobile and pick-up truck would be all over the road on a windy day. They obviously are not.
I have had both a DP and now have a gasser and I know from actual experience how to properly load and set up a coach for highway travel. Loading the coach to close to the maximum on the front axle is important and I also use four corner air bags to adjust for the wind conditions, much like the air bags on my previous DP.
The facts are that blanket statements just do not work. On this forum there have been owners complaining about how their DP handles in the wind, as well as gas coach owners with the same complaint. They never post their actual front and rear axle weights so it is not possible to know if the wandering is due to poor weight distribution or suspension problems. They just automatically blame the coach. Anyone that tows a trailer knows about proper weight distribution and it is just as important in a motor home.
