Colo_Native
Aug 29, 2017Explorer
Gas or DP
I am looking to go back to a MH, I want spend $70K -100K. It appears I could get a 3-4 old gas or a 8-10 year DP. I like the idea of a DP but wonder if the life is used up on a 10 year old DP and I ho...
Gjac wrote:
One thing to keep in mind is a short gas MH with 362 HP and weights 16,000 lbs will have a higher HP/wt ratio than a 300 or 340 HP DP that is closer to 30,000 lbs. Gas MH's have the same engine whether it is 28 ft or 38 ft. DP's HP go up as the length and weight go up.
