xctraveler
Nov 24, 2015Explorer
Gas Range burner not working
Went to turn on the left rear burner on the range top - Wedgewood Vision 3 burner - and it would not light. The other two burners light just fine. There is plenty of propane and water heater also works fine.
I lit the burner with a lighter and it lights, but burns with far more yellow than the other two burners - clearly needs the air/fuel ratio adjusted. Upon inspection, sparking the igniter with no propane on, the spark for the burner is not as intense as for the other two working burners.
So it appears there are two simultaneous failures on one burner. To the best of my knowledge nothing was dropped on that burner between the two mornings when DW used it to boil tea water.
I am open to suggestions for repair. Also what could have happened.
