Bruce_Brown
May 08, 2014Moderator
TucsonJim wrote:
Not a Class A Response, but here is my before and after:
Before
2004 Chevrolet 2500HD extended cab 4x4 6.0L Gas
2007 Keystone Cougar FW (Approx 9800#)
Speed on 6% grade - 35-40mph.
After
2013 Ford F350 Crew Cab, 4x4 6.7L Diesel
2014 Grand Design Reflection (Approx 12,900#)
Speed on 6% grade - 60-65mph with more pedal if I needed it!
Granted, the Chevy was 10 years older, and only had the 4 speed transmission. You can stay with a fifth wheel if desired and have all the power you need. But I'm guessing that if you want a MH, you'll see similar results in the power plants.
I 100% agree. The OP doesn't have a HP problem, he has a torque problem.
I might be able to offer a different perspective as we have both a DP and a Super Duty diesel w/ a TT. (Thats another story...)
Not the Grape Vine, but Rt 26 out of Johnson City, Tn;
2000 V10 gasser MH - brought to it's knees, 30 MPH tops
2003 DP w/ Cat 3126, 330HP/860 TQ - 55 MPH
We've never done that trip with our current MH (2008 DP, 400HP/1200TQ), but the power difference between the '03 and '08 is amazing. The '08 makes the '03 look a little weak.
A few years back we did the Yellowstone trip with our current MH, The Rockies didn't even make that one breathe hard.
With the TT, last year we did a Colorado Elk hunt; 5 guys with gear pulling a 33' Bunkhouse TT - '13 Super Duty Crew Cab, 8' box, pulling around 10,000#. The run from Cheyenne to Laramie Wy is a pretty long, steep pull. With the cruise set at 70 MPH the speedo never dropped below 69 MPH.
My suggestion to the OP - if you're otherwise happy with your fiver I'd suggest you take a good hard look at a new Super Duty Crew Cab w/ the 6.7 diesel. As mentioned, the Colorado trip was 5 grown men riding for 31 straight hours and we were all comfortable - and for the record I traded in an extended cab on the Crew Cab - night and day difference in the comfort level.
If you're ready for a DP skip the HP number and look at the torque.
And one more adder;
A friend of mine does the Northern NY to Florida run every winter with his toyhauler. A few years back his DuraMax needed more work than could be done before they were scheduled to make the trip, so he traded it in on a 6.0 gasser. The gasser made exactly one trip to Florida and back and was traded back in on another DuraMax. And not to turn this into a Ford/Chevy debate, that DuraMax was traded on a new Dodge Cummins 2 years ago, he is now shopping for a Super Duty. I will admit I am a Ford guy, but there is a reason you see so many Super Dutys pulling fivers. I'll also say none of them are bad by any stretch. If you choose to keep your fiver any new diesel truck would be sure to put a huge smile on your face.
38,766 PostsLatest Activity: Jan 10, 2026
