valhalla360
May 08, 2014Navigator
The two questions (diesel vs gas and 5th wheel vs MH) are almost completely unrelated.
5W vs MH has almost no bearing on how fast you can go up a hill.
HP and torque determine how fast you can go up a hill (assuming a similarly sized overall rig).
Assuming you like your current 5er, here's a relatively cheap suggestion: Find a 2005'ish, PU with a diesel. In decent shape, you are probably looking at $12-16k for the truck. See how that pulls the same trailer up the grapevine. I'm betting, your whole opinion changes.
- If it works, you've solved your problem for a whole lot less than a new diesel pusher.
- If it doesn't, you should be able to get better than 90% back by selling the truck when you go to buy the MH.
38,766 PostsLatest Activity: Jan 10, 2026
