slypig
Aug 29, 2014Explorer
Gas vs Diesel
Hello, I'm a newbe. Can I get some pros and cons between Gas and Diesel engines for a motorhome? Thanks
Peralko wrote:valhalla360 wrote:Peralko wrote:
High mileage can have a significant impact on the trade-in value of a gasser, but no impact on the value of a DP.
I think you forgot the smiley face to imply you were joking.
High milage will have a significant impact on either. Diesel will be slightly less impact depending on "how high" (assuming similar rigs of similar quality). Of course it comes with a much higher up front price also.
As others have said, get the floor plan you like. Unless you are going onto the carney circuit, you are unlikely to wear out either drivetrain due to miles.
Sorry, the drop in the value of a gasser is no joke! We put a lot of miles on our gasser, and found the value had dropped in half after two years!
Just as an example, I used a members gas coach (I won't say whose!), and used 10k miles, 40k miles, and 60k miles. The NADAvalues dropped from $110k to $104k and then to $99k just based on miles. That is certainly not a joke for gasser owners! Do the same with a DP, and it will not change. I agree floor plan is a big deal, but basically--put a lot of miles on a coach, get a diesel, minimum miles and a gasser may fill your needs.
