rockhillmanor
Dec 03, 2015Explorer II
tenbear wrote:
The gasket on the exterior of the window does not seal the window. Over time the gasket shrinks and pulls out of the corners. To put it back in you will have to pull it out from the nearest end and then push it back in starting at the corner that pulled out
X2
When they first start shrinking you can push them back in. Use your thumb and push hard until you feel it 'click' it to the slot. Then run around all of it pushing it back into that slot. Eventually they shrink too much and won't stay in.
