dan23 wrote:
I noticed this and thought I'd set the record straight in case anyone finds this thread via a search.
>>rgatijnet1 wrote:
Changing the injectors is not much harder than changing a set of plugs and I think you will end up being dollars ahead if you do it yourself.<<
Changing injectors is a LOT more work AND technically more difficult than changing spark plugs and no one who plans to attempt it should think otherwise. I'm not saying it is out of reach for quite a few, but be prepared for a dose of reality if you think the jobs are in any way similar in either regard.
Changed the injectors on my Ford F150 V8 and on my Ford V10 Excursion pretty easy actually, was easier to do the injectors on my Excursion than it is to do the spark plugs. Just saying.
