phnguyk wrote:
6 bolts to remove the upper manifold, move it to the side, and/or disconnect throttle cable and completely remove it. 4 bolts to remove fuel rail. Remove fuel line from rail. Pop out injectors. The point is you're already going through hell, replace them, rebuild, send them out, whatever floats your boat. You asked a question, we/I responded differently than you wanted. Good luck.
That's on the Ford engine. Different topic, but thanks, and good luck, too. There's no argument here for you to "win," so stop trying by posting off-topic.
