J-Rooster wrote:
rgatijnet1 wrote:
On my inverter/charger, it had a different setting for the standard lead acid batteries and for the AGM batteries. Make sure that the charger is set for the type of battery that you have.
Thanks for the info Ron, I'm learning a lot today, I'll check the setting on my inverter!
Here is what it says on my Xantrex inverter:
Battery ChargingCompletely charging wet cell deep-cycle
batteries requires the battery voltage to be
raised beyond what is known as the gassing
point. This is the voltage at which the battery
begins to bubble and gas is given off. If
charging stops short of this point, sulfate is left
on the plates and deterioration of the battery
begins. The gassing point will vary with battery
temperature.
At 77 ?F, the gassing point of a 12-volt
battery is about 14.0 volts.
AGM and Gel cell batteries must not be
charged to their gassing point. In fact, high-
voltage charging that gasses these batteries is
harmful to them. They typically require a lower
bulk charge voltage and a higher float voltage
than wet cell batteries. Consult the battery
manufacturer for specifications.
Freedom Battery ChargersFreedom battery chargers are designed
to overcome the limitations of conventional
chargers by utilizing three distinct charge
stages, each designed for optimal charging of
wet, gel cell and AGM deep-cycle batteries.
