J-Rooster's avatar
J-Rooster
Gel Cell Battery
When I got into my RV this morning it wouldn't start. I had to use the battery boost from my coach batteries to get the engine started. My chassis battery is a self contained Gel Cell battery around a year old that is dead and seems not to be taking a charge. I've been charging the Gel Cell battery for about 8 hours and it reads that it is still in the red (red indicator light means battery is not fully charged) on my battery charger. The green light on my battery charger indicates a full charge. I talked to my son and he told me Gel Cell batteries are very good batteries but, they need to be ran all the time not here and there (I've had my coach out twice in the last year). Has anyone experienced using a Gel Cell battery in a RV?
  • Pretty sure the factory Optima website is very clear that they make AGM batteries.
    Nothing else. No gel unless to explain that the battery is not a gel battery.
    Sometimes these are referred to SLA because they do fall into the Sealed Lead Acid group same as gel.
  • J-Rooster wrote:
    Thanks for everyone's help! Battery is charging at 14.5 and everything is working!
    That's great. According to my OBDII gauge, when the engine alternator on my coach needs to charge the batteries, it is usually at 14.4-14.5 volts. Sounds like everything is under control now.
    Thanks, Ron
  • usersmanual wrote:
    The whole top of the battery is Red! And it says Optima, AGM, High Performance Battery!
    well then its a Absorbed glass mat battery not a gel cell as Optima claim there AGM
    Thanks, The red top battery is completely self contained, I didn't mention that!
    Thanks for explaining that term to me (SLA).
