bigred1cav's avatar
bigred1cav
Gen leaking fuel
My 2001 39' Bounder is leaking fuel from the Gen I to date have been unable to find that rascal.
Where do you think it is most likely to be found?
  • X2 and I had one
    gbopp wrote:
    Did you check the fuel hoses and connections? The rubber hoses can rot or wear from rubbing against something.
  • Did you check the fuel hoses and connections? The rubber hoses can rot or wear from rubbing against something.
