- GreyghostExplorer
there is a on/off on the dash and the main on/off is on the gen itself. Use the one on the gen and it should shut off.
Neither of these switches worked on my Mountain Aire, consequently the only way to shut it off was to pull the fuse for the genset. - RamairExplorerthere is a on/off on the dash and the main on/off is on the gen itself. Use the one on the gen and it should shut off.
- GreyghostExplorerI had a similar problem on my Mountain Aire. I never found the source of the problem, but the only way I could shut off the genset was to pop the fuse. The on/off switch did not work.
- 2ndhomExplorerI wonder if the generator is still running?? :h
- 2ndhomExplorerMy generator has an on/off on the unit.
- BillofPAExplorerIf it's a diesel maybe the fuel solenoid won't close.
- wolfe10Explorer
Steve S wrote:
Is it still running?:B
Actually, a good question-- can't tell from the OP. - Steve_S1ExplorerIs it still running?:B
- mtrumpetExplorerAssuming that you're referring to the switch inside the coach as the "main switch", try going to the generator and shutting it off right at the generator.
- Mandalay_ParrExplorerSuspect a bad switch or a stuck relay.
I would pull the switch and pull the wires off first.
38,776 PostsLatest Activity: May 15, 2026
