roachcoach's avatar
roachcoach
Generac Generator
Installed a new starter in my generator and started up right away the first 2 tries then started to drag and click . I checked with a generator repair shop and was told to check my voltage at the batteries while cranking and to check my grounds. Is there anything else I should do?
Ok I tried starting up my generator with the engine running and it started right up. Not sure what to make of this but my mechanic is coming by tomorrow.
  • Ok the first starter we received was defective but the second starter worked great right off the top so looks like my problem has been taken care of.
  • Glad to hear that. Both my tech and a guy that specializes in Gennies,say that there has been a history of hit and miss starters. You may get a good one the first one out,or not. I am going to call the shop that replaced the three or four of them and see if they are lifetime warranties. I think the aftermarket ones are,but not the Generac.
  • Well the place I ordered starter from said that they seldom have a bad starter but they sent another starter to replace my defective one.
  • Where did you get your starter from. My OEM Generac starters came from
    someplace in the midwest,Wisconsin I think,but I don't know where the AM ones came from,but they weren't local. I just hate to pay another labor charge to replace another defective starter. It ain't cheap.
  • Got my am starter from ASAP out of Lebanon Pa. The am starters have a 1 yr warranty and the new Generac starters have a 3 month warranty so go figure. ASAP have very good customer service for a small co and would order from them again.
