PsnRebel
Feb 10, 2023Explorer
TechWriter wrote:
Fuel pump or hose to RV gas tank could need replacing.
Testing the fuel pump is fairly easy . . . disconnect your gen's fuel hose. Then connect another hose that's inside a gas can. Start your gen. If your it runs, then it's probably the pump.
I believe i can hear the fuel pump clicking when i depress the pre-heat switch on the front of the generator.
I couldn’t locate it the other day, i believe the pump is behind a removable panel on the bottom of the generator, which I couldn’t get to come off easily.
I’ve been having to dodge rain drops for this project…
38,782 PostsLatest Activity: Sep 10, 2026
