Community Alumni
Feb 10, 2023Not applicable
PsnRebel wrote:
So then in theory if I disconnect the #85 wire from the circuit board , terminal 12, the generator should start and run ?
I tried that and it still won’t stay running once I release the rocker switch (which I’ve tested per the manual).
Do not know about theory but if you unhook the wires at the oil pressure switch and the gen starts and runs then one of those switches is bad. I unhooked one at a time the first being the temp switch so I knew it was that switch. I did not test at the board.
Behind the front panel and in the upper right 1/4 is the oil pressure switch on that switch there is two wires, can not remember the color or number, one of the wires is for the oil pressure the other that goes to the right and behind the motor is for the temperature switch.
Also if you are holding down the preheat switch and the gen continues to run then you know the fuel pump is good.
JimR
- Hdcharley24Aug 12, 2024Explorer
Did you get this issue fixed? I have the same issue. Gen. Will run if you hold the preheat button. Shuts off when you let off.
- way2rollAug 12, 2024Trailblazer
you are responding to a topic that's a year old and community alumni doesn't exists on this page anymore. You may want to post your question in a new topic.
38,782 PostsLatest Activity: Sep 10, 2026
