PsnRebel
Feb 11, 2023Explorer
Yup same generator here! JimR 1 i wanted to thank you for your time, trying to assist me in this. I can read the manual, which is written pretty well for me to understand, but another outlook or explanation sometimes makes things a little clearer.
I just pulled off the front cover. And it looks as you described. Found the oil pressure switch. Trying to determine where heat temp switch is, im having trouble following the wires.
** on edit ** i removed. Each #85 wire (blue) from the oil pressure switch. No luck keeping it running with either wire disconnected.
Before pulling off the cover i held down the pre-heat switch while starting, i then kept it pressed after i let off the start/stop switch. It kept running, until i let off the pre-heat switch, then it startled to die. Pressed it again and it went back to running.
When i tested my pre-heat circuit the other day i didnt test the “pre-heat contactor” i have no idea where thats located and what it looks like. If anyone happens to know.
38,782 PostsLatest Activity: Sep 10, 2026
