TechWriter
Feb 12, 2023Explorer
wa8yxm wrote:TechWriter wrote:
Fuel pump or hose to RV gas tank could need replacing.
Testing the fuel pump is fairly easy . . . disconnect your gen's fuel hose. Then connect another hose that's inside a gas can. Start your gen. If your it runs, then it's probably the pump.
NOT on an RV generator no... The fuel pump on most RV generators is external (in-line type) and if you disconnect it and stick a hose into the gas can no gas will flow up into the carb.
It worked on my gen.
38,709 PostsLatest Activity: Mar 09, 2025
