Has anyone found issues in older gas generators using the current ethanol gas. Ours is a 1999 Onan 5500. I'm wondering if I should have any concerns or look for any telltale signs? Chuck
That is correct. Running the generator prevents most problems. The new gas doesn't turn to a varnish type residue like the old gasoline. It will leave a crusty like deposit that requires dismantling to clean out. Run the generator regularly, use a stabilizer from time to time, especially if the generator is going to sit for a month or so, and you should have no problems.
