Dutch_12078
Jun 16, 2013Explorer III
hipower wrote:ocean bound wrote:
Thank you pioiselle I received the camco brand for fathers day don't know if I should keep it my gen pipe comes out under rear bed room slide I will have to get a extend pipe about 2ft to bring it out to clear slide don't know if this will be safe. thank you
You may be able to loosen and reposition your existing exhaust pipe to better accomodate the Gen-Turi.
Either way I wouldn't be scared by adding a couple feet of additional pipe as long as it was at least the same size or bigger than the existing pipe.
Yep, if you can't reposition the stock pipe, install the appropriate Camco adapter on your existing pipe, and then buy the size extension needed sized to fit the Gen-turi elbow. You'll need to drill a matching hole in the extension for the spring pin, but that's simple enough. Just make sure you adequately support the riser pipe, so minimal weight is put on the stock exhaust pipe when the unit is in use.
