John_Joey
May 15, 2016Explorer
My bet is the main jet in the carb is plugged with varnish. Go to the store and buy a can of SeaFoam. Try to get as much as possible down that hose and into the carburetor bowl. Come back in 24 hours with a can of starter fluid. Shoot a little starter fluid down the carb while cranking over the motor. If it fires off you may have to keep lightly misting with starter fluid to keep it running. If it won't run after a minute or so without the starter fluid, rebuild the carb.
