- THE-RV-MANExplorerIt's a Marques onan 5000. The genny runs perfect. All the switches are on the on position. Breakers are fine. We hook up a meter an it puts out 60 not 120. But I did everything rite and still no power inside the RV.
- garry1pExplorerDo you have a transfer switch or do you have to plug your shore plug into the generator for power?
Is the generator putting out 120V at the generator breakers?
What kind and size of generator? - rvtenExplorerIs this MH new to you?
How about circuit breakers on the gen. itself?
Auto switch over circuit. - Mandalay_ParrExplorerDid you check the voltage output from the generator right at the gen?
Can you use a volt meter and find out where it is missing?
38,706 PostsLatest Activity: Feb 02, 2025
