CASERTA's avatar
CASERTA
Generator Problem
I have recently purchased a 2012 Winnebago ERA. The RV had 5000 miles and I have racked up another 11000 miles since my purchase in the Spring. (I really like my Sprinter Chassis!) Like everyone here, I have run into some minor problems and have generally enjoyed the process of exploring each problem and finding solutions. Until now!
My generator runs well and powers my A/C quite well. Unfortunately, I am unable to charge my battery with the 2500 Onan Generator. The battery charges well when connecting to AC Power as well as charging itself directly from the Alternator following the operation of the vehicle engine. Following the depletion of a day or two of camping including using a TV etc, the low voltage alarm occurs on my 1800 Watt Xantra (?) Inverter?Charger and am forced to run the engine to again charge the battery or just do without. On occasions when I find myself boondocking, I am forced to fun the vehicle engine to use things like a coffee maker and the TV.
I understand that the Inverter simply transforms DC to AC to allow me to run my TV etc. I am unsure where the problem lies. Is it likely the invertor or is it the generator? Is it likely I am neglecting to hit some switch someplace that would permit the charging of the house battery when the generator is engaged. I am perplexed and have needlessly run the generator many hours trying to find a solution. Everything else on the ERA is working fine and I am sure I am overlooking something obvious. Hopefully someone may have run across this problem and could give me a possible solution before I take the thing into a place for service. Thanks in advance for the help!
  • We have a 2013 ERA and the battery cutoff switch is just under the counter. It is a small rocker type switch which obviously only trips a relay. It does not carry all the battery power. Our ERA 70A might be a bit different than yours, but the manual we got describes the switch in detail and says where it is. Yours will likely as well.
    As others have said, running the genny to charge batteries and then use an inverter is not cost effective especially with a LP genny. Just run the genny when 110 volt is needed for a short time. Far more efficient.
  • Thanks Wayne. I didn't realize that the generator would take overnight to charge the battery. Someone had told me 30 minutes! I guess that I should only use the generator as a last resort and rely on the alternator to recharge the battery when I am unable to find AC Power readily available. I guess that the generator primary use will be to run the Air conditioning. I appreciate the reply. Paul
  • You did not say how long you run the generator. It will take many hours to recharge a battery from the converter. Overnight if it is really low. The engine alternator puts out much more. If you really want to charge from the generator the fastest way is to carry a good battery charger and with the generator running hook the charger to the battery, even this will take several hours if the battery is very low. The fastest way is the engine. Things like a coffee maker that produce heat use a lot of battery power. We always use the stove when boondocking.
    Good luck,
    Wayne
  • #40Fan, could you pleae let me know where I would possibly find a battery cut off switch?
    Old -Biscuit, the batterey definely charges when hooked up to AC power. Where exactly would I check for tripped AC power on the Xantex inverter? I have pressed a small button on the back of the invertor but with negative results.
    Thanks!
  • If you have an inverter which also charges then generator should provide AC power to inverter so charger can function.
    When hooked up to AC power does battery get charged?
    Check inverter for tripped ac power.....check charger output.
