MrWizard
Jul 07, 2015Moderator
I don't think it's sloshing in the tank
I don't know your current configuration
The OEM configuration is liquid feed, the tank has two valves top one is vapor for appliances and heater, bottom valve is liquid for the generator
Some owners changed the liquid feed system over to a vapor feed system
Honestly I don't know which one is better, or if it makes a major difference
Ours never gave us any trouble that way
But a 2/3 tank should have plenty of fuel
I would investigate the propane line routing, maybe it has been moved and engine heat is affecting it
This reminds me the 5.9 engine exhaust is under the generator
If something on this exhaust has been replaced, this might be a problem
