Kayteg1
Jul 08, 2015Explorer II
The liquid feed of propane has bad wrap from decades.
I had propane forklift that had heat exchanger for the propane using engine coolant.
From my observation lot of generators do have zigzag propane tubing running around the engine head for heat exchanger.
Add to it that sucking propane from bottom of the tank you are also sucking all the dirt, that vapor appliances will never see.
So not even going into what cost present problem, converting the feed from liquid to vapor would be suggested rather sooner than later.
38,782 PostsLatest Activity: Sep 10, 2026
