timmac
Sep 14, 2018Explorer
PhilipB wrote:
We have same generator in our 5er and similar problems. Ended up we were boiling the fuel. Made a shroud that vents the exhaust side away from the intake. You might try putting a fan under your coach and blow the exhaust side air away and see if that helps.
Yes this is correct, I had to make a shroud under the Gen/exhaust area to push the heat away from the intake and I also plugged up any openings in the Gen compartment to only get cool air thru the intake and this helped a lot, my Gen use to get hot and shut down now it stays running..
38,769 PostsLatest Activity: Mar 31, 2026
