Charley67's avatar
Charley67
Generator start/stop switch
The switch on my control board will not start the generator, but it will stop it. I removed the switch and checked for continuity. When I put the probes on the top two tangs and push the bottom side of the switch, I get the continuity beep. When I touch the bottom two and push the top, I also get the beep. This makes me think the switch is good. I have 12 volts on the hot wire. My dash switch and the one on the generator both work. I’m wondering if I have a corroded connection, but I don’t know where that wire goes. I tried looking at the wiring diagram but really couldn’t make much out of it. What do you think?
