dougrainer wrote:
RLS7201 wrote:
Unplug and plug the remote switch connector on the side of the generator several times. That connector is a known issue.
Richard
Yes, but his other remote switch works. I missed what he meant by "Control" Board. I thought he meant the ON Genset board. He must mean his Monitor panel. He needs to find where the Dash Switch and the Monitor panel wires connect to the Genset remote wire harness. THAT is probably where he has the problem. Most OEM's use tap splices to connect to the Onan remote wire harness and odds are the Tap splices are corroded or have come loose. Doug
Good catch. I should have read more closely.
Richard
