tropical36
Mar 29, 2019Explorer
prepilot_3ck wrote:
Yalls,
So, I have this 2016 class-A. It has about 6,000 miles on it, and a 5500W gas generator. The generator has about 300 hours (I think) on it.
It seems to start ok for the most part, sometimes it struggles, but it fires up. It will run for a period if time... and hour... hour 1/2... maybe 1/2 hour then it sputters out and quits. I can restart it, but it dies right away. The little light on my starter switch flashes after this happens. If I let it sit, off, for a LONG time . Like HOURS or over night, the flashing on the switch will stop and it will fire up again... then die again after a period of time.
Load doesn't seem to matter, parked vs. driving doesn't seem to matter. It just runs for some time, then pukes, and may or may not restart. I don't have my auto start turned on or anything.
It "feels" like it might be over heating. It's hot here in Vegas, and I can only imaging what the air trapped between the road.ground and the underside of the RV would be. Anyway, I'm not really sure how to trouble shoot this. There are no temp gauges or lights on the generator to indicate why it shut off. I called my RV dealer and they said "add stable to the gas tank and some sea foam". They think it's bad/stale gas or a gummed up carburetor.
Anyway, I don't think it's the gas, but I suppose it could be. Anyone else have any suggestions?
Thanks,
Brian
I'm betting on the oil OT switch and ended up disconnecting it for good, on our old Gasser, with a Generac 5.5. I would at least do so for troubleshooting purposes, regardless.
You might try giving the air intakes and outlets a good cleaning first and just for making sure of it's validity.
38,769 PostsLatest Activity: Mar 31, 2026
