et2 wrote:
brandonrv wrote:
Why not run the fridge off of propane?
It isn't propane. Runs on electric only. So what is the consensus? The MH will charge all batteries, or just the starter set?
Two ways to know for sure: call Fleetwood with your vin number and they should be able tell you; get out a volt meter and see what happens to the voltage across the batteries when the running. Try this after a day's run. If the voltage shows around 13, the alternator is charging them. If they are under 12.6 v it isn't. This way you will KNOW.
