went to run the generator for the monthly visit, and won't start, finally figured out blown fuse... replaced fuse and now it will crank but won't run... thought might me a plugged fuel filter, when I ...
I believe the pump will stop until it builds up enough pressure. An open fuel line will not allow it to build up any pressure. Try hooking everything back up and then see if the pump stops. Try using your BOOST switch when you start the generator.
