B_B_Upch
Jul 15, 2016Explorer
genset bogs down under load
So my onan 7000 marquis runs great until I try to put it under a load & then it bogs down. & eventually dies. It's bogs down to the point Tha it will not run my a/c but for just a second. I put new oil filter & oil (it is level) & new fuel & air filter on it. Tried cleaning the carb by running fuel & b12 in a gallon can thru it but still no change. Also cleaned the rings & still the same thing. I'm thinking of replacing the fuel pump next but it is the expensive 149-2267 on it now. Cam I replace it with the cheaper smaller one & mount it somewhere else? What else do you suggest?
