bsiemens's avatar
bsiemens
Genset won't keep running
Hope someone has an answer before I shell out money for ANOTHER new carborator. Genset didn't run when I bought my 2014 Winnagago Sighseer, No problem got it a good price and expected to put some money in it. $300 dollars for a carborator and the genset is running perfectly. That was 2 years ago. I start and exercise the genset every month for at least 45- 60 minutes. Last time out genset sarts and runs fine but after about 15 miutes it begins to back fire spit and quits. At first this was only under a load such as AC running. Now it has begun this back fire without being under a load. An RV repairman told me that the carborator was bad again because I should have put in a gas cut off. He said that gas left standing in carb deteriorates the carb and is the cause of the problem. Ever hear of this? I sure hate to shell out for another carborator so soon. I really don't know anything about these genertors but the rest of the coach is perfect.
  • Make and model of the genset would help.
    If it has a fuel pump that could be the issue.
  • are you the least bit Handy ?
    i would get 3-5gal can of gas,
    a can of Sea-Foam
    mix the sea foam in the gas
    disconnect the fuel hose inlet to the fuel pump
    connect a piece of fuel hose and put in the gas can
    get generator started run until gas is gone, 4 hrs ? or more,
    may have to get some fuel into carb let soak overnight
    then run it it the next day, keep it running until it smooths out and runs right
    install fuel cut off
    in RVs being stored sta-bil in the fuel is a good idea
    for preparation, also buy a spray can sea foam,
    on the day before remove fuel hose from carb and insert spray nozzle and fill carb with sea foam spray
    let it set overnight, before running the sea-foam gas thru the carb and engine,
    NOTE expect a lot of smoke, that is normal when using sea foam
  • Gas left in the carb doesn't "deteriorate the carb", it rots and turns into crud that plugs the carb passages. The carb doesn't necessarily need replaced, a decent mechanic should be able to clean it and put a repair kit in it for a lot less than $300!
    Once you get it running, put Sta-Bil in the gas tank, then run the engine and the generator to get it well distributed. That's what I do, and I have never had a carb problem since I started doing it. Follow the instruction on the label.
  • He's correct in that you need to add a shutoff inline and kill the fuel flow, then run it dry, before letting it sit up. It can probably be cleaned with carb cleaner if it isn't bad and fixed with a rebuild kit if it's worse, and someone takes the time. Might be cheaper to buy a new carb then pay for the labor, though.
    You also need to run something like STA-BIL if you're not running through an entire tank every month or so.
