dougrainer wrote:
prism wrote:
tkranz wrote:
Might have already posted this. On my older RV, I had HWH jacks with manual valve levers. I could gently retract the jacks.
On my newer rig, I have touch pad controls. The minute I hit the "store" button, they come down suddenly and hard. Am I missing something, or is this how they are supposed to work?
DONT hit the store button.Tap the front down and the back down and it will lower way less harshly.Once your almost down then hit the store button. Big big screw up on HWH part for sure
If you read his post correctly, you would realize he has MANUAL levers, NOT a touch pad system. Regardless, you do NOT have to "tap" the Touch pad type system. If the retraction rate is too severe for you, install the Velocity valves. Doug
OP with highlighted text...
