Raymon wrote:
SCVJeff wrote:
(Answer from the FAQ): "Your disabled vehicle will be towed to the nearest repair facility qualified to repair your vehicle."
Do they qualify repair facilities? If so maybe CW is not a qualified repair center?
For a flat tire? Not when I had a flat tire; changed the tire on site.
Ray
They only send out a truck once.
If you ask for a tire and they find the blown tire caused so much damage you can not drive it then you need a tow and that expense will be all yours.
Best to ask for tow truck with a tire imo. If a simple tire change great. If you need a tow it is already there.
