dougrainer wrote:
1. I have NEVER seen an Icemaker trip a GFCI (39 years)
2. I HAVE seen a Refer (RV) trip a GFCI due to a faulty 120 element
3. If you suspect the refer is ON the GFCI circuit, just turn the refer OFF. If the GFCI fault goes away, then replace the refer 120 element/s. Doug
PS, if you have NO idea what and how various wires are used/connected. STOP. You can create more problems and when you decide to have a professional look at it, it will be harder for him to get various receptacles wired up. It will increase your bill.
Listen to Doug. His advice (both times) are right on. You DO NOT want to replace a GFCI with a regular receptacle. It's tripping to protect you. Changing it means that protection goes away. I will also second Dougs suggestion of getting a professional to look at it if you're the least bit hesitant or if you don't understand how it works. GFCI circuits are pretty simple but mfgs make them more difficult. Monaco uses GFCI protected breakers which are a lot easier. If you're going to keep playing with this yourself, be sure to ask questions as you go. If you're not sure, stop and ask. There are no silly or dumb questions, especially when you're working with electricity. BTW, you do have a meter for testing yes?...Dennis
