I have a 06 National Sea Breeze and when I go to start the gemerator or plug in 50 amp service the bathroom GFI is tripped! When I reset it it is ok and works fine till next time I plug in again or tu...
Neutral is white, bare or green is ground, red or black is hot.
I would look in the transfer switch. Also common for the fridge heat element to get grounded. Does the GFI trip if fridge already running on utility power when you start the generator?
