- Snowman9000ExplorerAnother vote for CPES. Incredibly good.
- j-dExplorer IIOk, Mike, then another alternative...
RotDoctor/DrRot
I used their "CPES" on a project. A couple points:
1. The product must penetrate deeply on the first application. Otherwise, the wood will be "waterproofed" against further application. Those application(s) won't reach the inner recesses of the rot.
2. RotDoctor's CPES is TOXIC. Highly evaporative so it really gets into the air where you're working. Requires tons of ventilation. - mikeleblanc413Explorer
Dick_B wrote:
Just to complicate the decision I have had good luck with Minwax Wood Hardener; probably the same stuff. Once the wood is hardened I use Minwax Wood Filler which hardens to be able to be filed, drilled, painted.
Dick_B...doesn't complicate at all...gives me one more option to explore...I'll check it out...THANKS!!!! - Dick_BExplorerJust to complicate the decision I have had good luck with Minwax Wood Hardener; probably the same stuff. Once the wood is hardened I use Minwax Wood Filler which hardens to be able to be filed, drilled, painted.
