martin_wExplorerJun 03, 2013gm 8.1 engineI have 2006 fleetwood flair with 6000 mi need to add oil about every 900mi . I see no leak on the ground or gray or black smoke. Wayne
harold1946ExplorerJun 03, 20131 quart used every 1000 miles is not unusual for thr 8.1 and not an indication of anything wrong.The 8.1 does not have a PCV valve.If you have the Workhorse chassis manual it will tell you 1 quart every 1000 mi. is normal.
Related Content8.1 Engine Running HotGM 8.1 Workhorse O2 SensorsPotential engine overheatingGM's New LT6 EngineWorkhorse 8.1 engine problem/history
