martin_w
Jun 03, 2013Explorer
gm 8.1 engine
I have 2006 fleetwood flair with 6000 mi need to add oil about every 900mi . I see no leak on the ground or gray or black smoke. Wayne
harold1946 wrote:
I should add that when I fill my crankcase, per the manufacturer's specs, it comes to just slightly(1/8") above the "add oil" mark on my dipstick. After 70,000+ miles on my engine, I usually go 5-6000 miles before I need to add a quart of oil. If I added oil up to the "full" mark on my dip stick, I would have overfilled the crankcase.
When was the last time you saw the dipstick of an 8.1 with the wrong markings? If the required 6.4 quarts are in, it is not over filled.
Sounds like your engine manufacturer has a problem with quality control.
