Go_Dawgs1
Jun 09, 2013Explorer
I have an 03 Chateau Sport 26Q on a 3500 GM chassis with a 8.1 Vortec. My GVWR is 12,500 and the tow rating is 5000lbs. Any gas MH will probably be limited to 5000lbs towing. Diesel will go much higher. If you are looking at 25' or less then your weight will be fine and most newer Class C are on the E450 Superduty. You might also look at the Sprinter Class C's some on Mercedes and some on Dodge chassis with both gas and diesel. Look at a couple today. Nice rigs and roomy.
38,782 PostsLatest Activity: Sep 02, 2026
