FunTwoDrv wrote:
Kamphiker, it was an option with the 4500 chassis. However, I wasn’t successful in having GM reprogram the new instrument cluster to add it. So, now I’m leaning towards the Scan Gauge option as there is a nice place to install it on the dash.
Thanks for the advice everyone.
Gary
I have mine sitting on top of the steering column in the Navion. It's line of sight with the other instrument cluster gauges. I run all 3 temp gauges - coolant, oil, and transmission (I think temps tell you a lot about what's going on under the hood) and either a DPF Regen monitor, or a charging voltage gauge as #4. Plenty of other options, too.
