Johnny_Hurryup
Aug 17, 2022Explorer
"Godzilla" Ford V 8
Does anyone know why the new Ford "Godzilla" V8 7.3 liter is rated at 350 HP in a Class C motorhome but 430 HP in a Ford F250 superduty truck? The torque ratings are similar though,
valhalla360 wrote:Grit dog wrote:valhalla360 wrote:
Realistically, how many people drop $70-90k on a truck and go around with it floored at 5,500rpm with a heavy load.
More than just in a stoplight race or a burnout?
Only those that bought a 7.3 gasser to haul their 14k 5ver anywhere in the mountains, because "a diesel is too expensive and unreliable."
LOL
Show me a burnout/drag race where they can get the 7.3 engine up to 5,500rpm with heavy torque to max out the HP.
Yeah, you might be able to force it into a low gear and get up to 5,500rpm but the torque will be way below max available at that rpm. By the time you get up into the higher gears it's tough to get the rpm up that high without hitting max speeds due to wind resistance.
Reality is very few engines will ever develop the max rated HP and most owners don't want to thrash a very expensive new truck, so it's mostly about bragging rights.
LOL
DaButcher wrote:
Just in case the standard RV horsepower of the Godzilla engines isn't enough add a couple turbos to get 1100+ HP.
Twin-Turbo Ford 7.3L Godzilla V8 Pumps Out 1,100 Horsepower
pnichols wrote:bobndot wrote:
I guess the idea was for the rv engine to get better mpg's.....???
bc it's operating at lower rpms where its tuned to get peak HP and torque at a lower rpm ,
where the fuel injection settings are tuned at peak.
Super Duty chassis with the 7.3 engine is tuned to produce 430 hp at 5,500 rpm. The Premium RV 7.3 is tuned to produce 350 hp at 3,750 rpm.
I think its better suited for the rv which is always hauling its weight where a P/u is not. To have power early on , lower rpm's, is a benefit in an rv.
Hmmm ... other than in drag, or closed course, racing ... what pickup driver (or RV driver) revs their 7.3 V8 to 5,500 rpm?
I'm guessing that the "RV tuned version" of the 7.3 V8 would probably be putting out close to 430 hp too ... at 5,500 rpm.
