Golden_HVAC
Dec 03, 2013Explorer
What I would recommend is using another 120 volt power plug from inside the house. The laundry room should be on it's own 120 volt circuit breaker, so is the dishwasher in many modern homes.
If you have a friend with a 30 amp 4 wire dryer, you can make an adapter from 30 amp dryer to 50 amp stove receptacle, both at Home Depot, it will be a lot more power than that 120 volt 15 amp receptacle will put out too. Just buy a 30 amp dryer cord (they come 4' long) and a surface mount 50 amp stove receptacle. Put them together, you have a adapter that will run both heat pumps, or 2 A/C units in your RV.
