RoyB
Feb 26, 2014Explorer III
Pickup a couple of MIDLAND GXT1000VP4 3 FRS radios from AMAZON.
Be sure the packaga comes with Pair of radios, belt clips, desktop charger, rechargeable batteries, pair of mic headsets, AC wall adapter, and DC (vehicle) adapter.
Just be aware the FRS radios are on a public radio network much like the old CB bands and is not private. Others may hear your radio transmissions... Also this is a very popular radio net to use and when you get into populated areas you will hear others using the same frequencies. These radios should be Voice Operated just like your cell phones... I always wear my ear piece on the right ear to make it more non-visible from outside the truck. You can select PRIVATE communications and not hear others using the same frequency but if two of you are ON at the same time you may not hear your other private party.
We use ours in GATLINBURG alot while the wife hits all the shops and stores and I head for the mountain trails for a few hours. These radios are line of sight with only a mile or so range...
These are not expensive - AMAZON lists the pair for $62 - Like on CB NO FCC license required.
Roy Ken
Roy Ken
